David
Former Developer
Hey,
I've just uploaded the latest files for vBNotifications. Permanent notifications and dismissing should once again work as normal!
Thanks,
David
Download the files, and upload them, overwriting old ones, then import the xml, and see is it does work for you.
Sometimes stuff reacts different on different server configurations.
Not working for me either. On vb 4.1.3 PL1. Still using the default vbulletin notification system even when enabled, and settings set.
Using Fire Bug
David I can see this
Line 384
this.throw_ajax_error = function(error) {
console.error(this.timestamp() + "AJAX Error: %s", error);
Line 7
YAHOO.util.Connect={_msxml_progid:["Microsoft.XMLHTTP","MSXML2.XMLHTTP.3.0","MSXML2.XMLHTTP"],_http_headers:{},_has_http_headers:false,_use_default_post_header:true,_default_post_header:"application/x-www-form-urlencoded; charset=UTF-8",_default_form_header:"application/x-www-form-urlencoded",_use_default_xhr_header:true,_default_xhr_header:"XMLHttpRequest",_has_default_headers:true,_isFormSubmit:false,_default_headers:{},_poll:{},_timeOut:{},_polling_interval:50,_transaction_id:0,startEvent:new YAHOO.util.CustomEvent("start"),completeEvent:new YAHOO.util.CustomEvent("complete"),successEvent:new YAHOO.util.CustomEvent("success"),failureEvent:new YAHOO.util.CustomEvent("failure"),abortEvent:new YAHOO.util.CustomEvent("abort"),_customEvents:{onStart:["startEvent","start"],onComplete:["completeEvent","complete"],onSuccess:["successEvent","success"],onFailure:["failureEvent","failure"],onUpload:["uploadEvent","upload"],onAbort:["abortEvent","abort"]},setProgId:function(a){this._msxml_progid.unshift(a);},setDefaultPostHeader:function(a){if(typeof a=="string"){this._default_post_header=a;this._use_default_post_header=true;}else{if(typeof a=="boolean"){this._use_default_post_header=a;}}},setDefaultXhrHeader:function(a){if(typeof a=="string"){this._default_xhr_header=a;}else{this._use_default_xhr_header=a;}},setPollingInterval:function(a){if(typeof a=="number"&&isFinite(a)){this._polling_interval=a;}},createXhrObject:function(g){var d,a,b;try{a=new XMLHttpRequest();d={conn:a,tId:g,xhr:true};}catch(c){for(b=0;b<this._msxml_progid.length;++b){try{a=new ActiveXObject(this._msxml_progid[b]);d={conn:a,tId:g,xhr:true};break;}catch(f){}}}finally{return d;}},getConnectionObject:function(a){var c,d=this._transaction_id;try{if(!a){c=this.createXhrObject(d);}else{c={tId:d};if(a==="xdr"){c.conn=this._transport;c.xdr=true;}else{if(a==="upload"){c.upload=true;}}}if(c){this._transaction_id++;}}catch(b){}return c;},asyncRequest:function(h,d,g,a){var b=g&&g.argument?g.argument:null,e=this,f,c;if(this._isFileUpload){c="upload";}else{if(g&&g.xdr){c="xdr";}}f=this.getConnectionObject(c);if(!f){return null;}else{if(g&&g.customevents){this.initCustomEvents(f,g);}if(this._isFormSubmit){if(this._isFileUpload){window.setTimeout(function(){e.uploadFile(f,g,d,a);},10);return f;}if(h.toUpperCase()=="GET"){if(this._sFormData.length!==0){d+=((d.indexOf("?")==-1)?"?":"&")+this._sFormData;}}else{if(h.toUpperCase()=="POST"){a=a?this._sFormData+"&"+a:this._sFormData;}}}if(h.toUpperCase()=="GET"&&(g&&g.cache===false)){d+=((d.indexOf("?")==-1)?"?":"&")+"rnd="+new Date().valueOf().toString();}if(this._use_default_xhr_header){if(!this._default_headers["X-Requested-With"]){this.initHeader("X-Requested-With",this._default_xhr_header,true);}}if((h.toUpperCase()==="POST"&&this._use_default_post_header)&&this._isFormSubmit===false){this.initHeader("Content-Type",this._default_post_header);}if(f.xdr){this.xdr(f,h,d,g,a);return f;}f.conn.open(h,d,true);if(this._has_default_headers||this._has_http_headers){this.setHeader(f);}this.handleReadyState(f,g);f.conn.send(a||"");if(this._isFormSubmit===true){this.resetFormState();}this.startEvent.fire(f,b);if(f.startEvent){f.startEvent.fire(f,b);}return f;}},initCustomEvents:function(a,c){var b;for(b in c.customevents){if(this._customEvents[b][0]){a[this._customEvents[b][0]]=new YAHOO.util.CustomEvent(this._customEvents[b][1],(c.scope)?c.scope:null);a[this._customEvents[b][0]].subscribe(c.customevents[b]);}}},handleReadyState:function(c,d){var b=this,a=(d&&d.argument)?d.argument:null;if(d&&d.timeout){this._timeOut[c.tId]=window.setTimeout(function(){b.abort(c,d,true);},d.timeout);}this._poll[c.tId]=window.setInterval(function(){if(c.conn&&c.conn.readyState===4){window.clearInterval(b._poll[c.tId]);delete b._poll[c.tId];if(d&&d.timeout){window.clearTimeout(b._timeOut[c.tId]);delete b._timeOut[c.tId];}b.completeEvent.fire(c,a);if(c.completeEvent){c.completeEvent.fire(c,a);}b.handleTransactionResponse(c,d);}},this._polling_interval);},handleTransactionResponse:function(b,j,d){var f,a,h=(j&&j.argument)?j.argument:null,c=(b.r&&b.r.statusText==="xdr:success")?true:false,i=(b.r&&b.r.statusText==="xdr:failure")?true:false,k=d;try{if((b.conn.status!==undefined&&b.conn.status!==0)||c){f=b.conn.status;}else{if(i&&!k){f=0;}else{f=13030;}}}catch(g){f=13030;}if((f>=200&&f<300)||f===1223||c){a=b.xdr?b.r:this.createResponseObject(b,h);if(j&&j.success){if(!j.scope){j.success(a);}else{j.success.apply(j.scope,[a]);}}this.successEvent.fire(a);if(b.successEvent){b.successEvent.fire(a);}}else{switch(f){case 12002:case 12029:case 12030:case 12031:case 12152:case 13030:a=this.createExceptionObject(b.tId,h,(d?d:false));if(j&&j.failure){if(!j.scope){j.failure(a);}else{j.failure.apply(j.scope,[a]);}}break;default:a=(b.xdr)?b.response:this.createResponseObject(b,h);if(j&&j.failure){if(!j.scope){j.failure(a);}else{j.failure.apply(j.scope,[a]);}}}this.failureEvent.fire(a);if(b.failureEvent){b.failureEvent.fire(a);}}this.releaseObject(b);a=null;},createResponseObject:function(a,h){var d={},k={},f,c,g,b;try{c=a.conn.getAllResponseHeaders();g=c.split("\n");for(f=0;f<g.length;f++){b=g[f].indexOf(":");if(b!=-1){k[g[f].substring(0,b)]=YAHOO.lang.trim(g[f].substring(b+2));}}}catch(j){}d.tId=a.tId;d.status=(a.conn.status==1223)?204:a.conn.status;d.statusText=(a.conn.status==1223)?"No Content":a.conn.statusText;d.getResponseHeader=k;d.getAllResponseHeaders=c;d.responseText=a.conn.responseText;d.responseXML=a.conn.responseXML;if(h){d.argument=h;}return d;},createExceptionObject:function(h,d,a){var f=0,g="communication failure",c=-1,b="transaction aborted",e={};e.tId=h;if(a){e.status=c;e.statusText=b;}else{e.status=f;e.statusText=g;}if(d){e.argument=d;}return e;},initHeader:function(a,d,c){var b=(c)?this._default_headers:this._http_headers;b[a]=d;if(c){this._has_default_headers=true;}else{this._has_http_headers=true;}},setHeader:function(a){var b;if(this._has_default_headers){for(b in this._default_headers){if(YAHOO.lang.hasOwnProperty(this._default_headers,b)){a.conn.setRequestHeader(b,this._default_headers[b]);
}}}if(this._has_http_headers){for(b in this._http_headers){if(YAHOO.lang.hasOwnProperty(this._http_headers,b)){a.conn.setRequestHeader(b,this._http_headers[b]);}}this._http_headers={};this._has_http_headers=false;}},resetDefaultHeaders:function(){this._default_headers={};this._has_default_headers=false;},abort:function(e,g,a){var d,b=(g&&g.argument)?g.argument:null;e=e||{};if(e.conn){if(e.xhr){if(this.isCallInProgress(e)){e.conn.abort();window.clearInterval(this._poll[e.tId]);delete this._poll[e.tId];if(a){window.clearTimeout(this._timeOut[e.tId]);delete this._timeOut[e.tId];}d=true;}}else{if(e.xdr){e.conn.abort(e.tId);d=true;}}}else{if(e.upload){var c="yuiIO"+e.tId;var f=document.getElementById(c);if(f){YAHOO.util.Event.removeListener(f,"load");document.body.removeChild(f);if(a){window.clearTimeout(this._timeOut[e.tId]);delete this._timeOut[e.tId];}d=true;}}else{d=false;}}if(d===true){this.abortEvent.fire(e,b);if(e.abortEvent){e.abortEvent.fire(e,b);}this.handleTransactionResponse(e,g,true);}return d;},isCallInProgress:function(a){a=a||{};if(a.xhr&&a.conn){return a.conn.readyState!==4&&a.conn.readyState!==0;}else{if(a.xdr&&a.conn){return a.conn.isCallInProgress(a.tId);}else{if(a.upload===true){return document.getElementById("yuiIO"+a.tId)?true:false;}else{return false;}}}},releaseObject:function(a){if(a&&a.conn){a.conn=null;a=null;}}};(function(){var g=YAHOO.util.Connect,h={};function d(i){var j='<object id="YUIConnectionSwf" type="application/x-shockwave-flash" data="'+i+'" width="0" height="0">'+'<param name="movie" value="'+i+'">'+'<param name="allowScriptAccess" value="always">'+"</object>",k=document.createElement("div");document.body.appendChild(k);k.innerHTML=j;}function b(l,i,j,n,k){h[parseInt(l.tId)]={"o":l,"c":n};if(k){n.method=i;n.data=k;}l.conn.send(j,n,l.tId);}function e(i){d(i);g._transport=document.getElementById("YUIConnectionSwf");}function c(){g.xdrReadyEvent.fire();}function a(j,i){if(j){g.startEvent.fire(j,i.argument);if(j.startEvent){j.startEvent.fire(j,i.argument);}}}function f(j){var k=h[j.tId].o,i=h[j.tId].c;if(j.statusText==="xdr:start"){a(k,i);return;}j.responseText=decodeURI(j.responseText);k.r=j;if(i.argument){k.r.argument=i.argument;}this.handleTransactionResponse(k,i,j.statusText==="xdr:abort"?true:false);delete h[j.tId];}g.xdr=b;g.swf=d;g
Using Fire Bug
Line 384
Line 7
Could you expand that error and post the results here (Click the + sign on the bit under the error)
Hello David not sure there was anything of interest there...but what do I know :p
I did find this for line 7
* You may not copy/reproduce any part of this file in whole or significant part.
Does anyone have it working on 4.1.4?
Legacy vBNotifications
