sure give me code i will run on the database just with steps
truncate table dbtech_downloads_categories
That will clear out all of the categories
If you have a prefix you have to put that in. So if you have vb_ as a prefix then change it to
truncate table vb_dbtech_downloads_categories
I'm installing downloads II on my local system to try out the import
ok it deleted the categories now :p & in ur docs u don't tell give permission to the folders where we set?
r u testing on our site ? since i see again categories reappear? & u can see how it was in downlodsII
No, I might have run an import just after you truncated the table. I'm working on the code on my local system right now
Once their is a update he will post it here, it has been only 5 hrs since he started working on it, and probably is sleeping now.
any updates?
I have the importer fixed for parent relationships.
You can either give me ftp access to upload it or you can unzip this file to the dbtech/downloads/core folder and overwrite the old file.
You will want to truncate the table again before you run this.
It only failed on a few files which makes me think they aren't there. Can you verify they are there and are named the same?
I'll change the permissions for the next update.
I'm not sure what you mean about the add subcategory thing?
Sent from G2 via Tapatalk
looks like it copied all the 34 files & where ever there is http:// (./downloads/http://www.) its failed or giving that warning. But it did not copy the thumbnail images from it
I'll check out the problem with the link files.
The believe images weren't added into the importer because they are stored differently between the two systems. I'll look at it but I can't promise I'll get them to come across.
But atleast you should have vb dynamics categories styling . since its good way of showing things & organizing
you can login to our admincp & you can check
Are you talking a list type view as if you are looking at all the threads in a forum?
We can add that but it wont happen quick. Just add a feature request and it will be considered for the next release.
Legacy vBDownloads
