saucerfoot
Hey staff
I installed the triple Triad lite version on my board
but when i try to buy some cards, it won't load onto the next page for me
so could you guys help me with this please
this is what it saids when i try to buy a card pack on my board
Fatal error: Maximum execution time of 30 seconds exceeded in /home/saucerfo/public_html/forum3/dbtech/tripletriad/core/core_tripletriad_buy.php on line 98
You'd need to create your red/blue card images first, once that's done you can add a new set in the ACP (under Manage Triad Sets). After adding the set you need to go through an add elements (if you want the set to use them) and Card Levels. Once that's all done you can begin adding cards to the set. The structure of the set needs to be consistent too, take a look at your folder: ./dbtech/tripletriad/packs/final_fantasy_viii - you'll need to create a folder inside /packs called "pokemon", then that folder should contain all the images for the set, you can use images from the FF8 set as a basis.
Additionally you can check out our Pokémon set here: http://www.dragonbyte-tech.com/tripletriad.php?do=database&tab=13, which you can buy here, all sets work with Lite and you can easily import them :)
If you're still unclear on how to do things, you should read the documentation available here: http://www.dragonbyte-tech.com/content/45-tt-documentation
Legacy Triple Triad
