riskreward
I try to enter different Block ID in the Info Panel setting. But no matter what different ID's I enter, the display on the main page is set to new members, top posters and new replies. How do I get it to change to what I want.?
They don't change for you because you have loaded the Top X Stats at least once with the existing blocks, which saves the configuration for your user :)
It will have changed for guests / new members, though. There's no way to update existing members' configs, sorry.
Same issue as the OP. This is very unfortunate that the blocks don't change for me when I adjust the settings. If I log out, though, I see the changes.
So, the only resolve is to uninstall/reinstall the product, then give the settings to my liking?
In the Pro version, where the blocks are saved to the DB, you can use the drop-down next to each block title to change your blocks.
You can run
UPDATE user SET dbtech_infopanels_blocks = NULL
though.
Remember to add your table prefix if you use one.
Legacy InfoPanels
