LRReaper
Hello I just recently installed vbseo and stumbled upon a little problem in the shoutbox. When you click on their name in the shotubox and the tab pops up. When you go click on "View Profile" from the tab it only takes you to /forums/member.php of that certain member and doesn't follow the custom input from vbseo that I have which is [user_id]-[username].html.
Is there any way of fixing this? Thanks! :)
There's no way to have vBSEO rewrite these URLs, and doing so would be exceptionally bad for performance. We strongly recommend disabling vBSEO for vbshout.php because of the added resource usage.
Done. Member urls still not working in the shoutbox. Anything else I have to change/do? Thanks! :)
A few days ago I implemented a change that may help you. Try re-downloading the Lite version from DBTech, re-uploading and re-importing the XML file.
