Already had the lite version installed, ordered the Pro Version and installed last night. I do not see the Forum Block or CMS Widgets, even though I have them enabled in the Settings. Help! This is the reason I got the Pro Version to begin with. And yes there have been nominations since I added the Pro Version :)
Sorry for the delay in responding, hectic with the holidays :(
Could I get access so I can see what's going on?
I don't see any completed nominations? The blocks don't show up until you have something completed and scored.
Correct, it shows a list of the nominations that were won, not the ones currently running.
They weren't setup correctly for some reason. I went in and fixed the forum sidebar one, but it's disabled until you are ready for it. The CMS one wasn't there at all so I created it and tested it out. All you have to do when it's ready is to add it to the layout you want to display it on, it's called Nominations
Legacy vBNominate
