angus
Hello!
Since version 1.1 there are avatars of the users next to the usernames in the what´s going on block.
Please be not angry with me, but that looks totally ugly.
How can I disable these avatars?
Angus
Really no way???
What about a change of templates. Somewhere there must be the code to set an avatar.
It's not handled by a template, and file edits aren't supported. If it's really bothering you then you can remove the if block that starts with
if ($vbulletin->options['avatarenabled'])
from /dbtech/infopanels/hooks/forumhome_loggedinuser.php but we're unable to provide support for changes or problems that occur as a result of changes like these :)
Thank you very much.
I think more people will enjoy if you could install such an option.
Angus
Yes, as much I enjoy having them in forum home for logged in users. There needs to be an option. :)
I prefer to have them but if someone does not...
I agree just updated and its the most uglist thing when u have over a 1000 members online, get rid or add option to disable. Could you display the full block details to remove to get rid please
---------- Post added 21st December 2011 at 22:42 ---------- Previous post was 19th December 2011 at 23:16 ----------
Guess not, disable that as unusable, like most of the DBtech mods :-(
Instructions for how to remove it in wait of an option have been posted earlier in this thread :)
Can you please be a bit more specific as to the exact code that needs to be removed here? Thank you so much. It really does not look good when you have a lot of members online.
I am unable to get the double commas to show like you do. Ensure you have removed the following entire code from /dbtech/infopanels/hooks/forumhome_loggedinuser.php
    if (!function_exists('fetch_avatar_url'))
        // Get the avatar function
        require_once(DIR . '/includes/functions_user.php');
    if ($userid == $vbulletin->userinfo['userid'])
        if (!$vbulletin->userinfo['avatarurl'])
            // Get avatar URL
            $avatarurl = fetch_userinfo($userid, 2, 0, 1);
            // Add avatar info to loggedin array (VB Y U FORCE ME TO DO THIS)
            $loggedin['avatarpath']         = $avatarurl['avatarpath'];
            $loggedin['hascustomavatar']     = $avatarurl['hascustomavatar'];
            $loggedin['avatardateline']     = $avatarurl['avatardateline'];
            $loggedin['avwidth']             = $avatarurl['avwidth'];
            $loggedin['avheight']             = $avatarurl['avheight'];
            $loggedin['avheight_thumb']     = $avatarurl['avheight_thumb'];
            $loggedin['avwidth_thumb']         = $avatarurl['avwidth_thumb'];
            $loggedin['filedata_thumb']     = $avatarurl['filedata_thumb'];
            $loggedin['avatarid']             = $vbulletin->userinfo['avatarid'];
            $loggedin['avatarrevision']     = $vbulletin->userinfo['avatarrevision'];
            // Yay it's available in vB3 after all :D
            fetch_avatar_from_userinfo($loggedin);
        else
            // Just in case...
            $loggedin['avatarurl'] = $vbulletin->userinfo['avatarurl'];
    else
    // Set musername
    $loggedin['musername'] = '<img border="0" src="' .  $loggedin['avatarurl'] . '" alt="" width="20" height="20" /> ' .  $loggedin['musername'];
+1 for adding this option in a new version. It doesn't look too great when you have lots of users on-line at ones, especially for those people who have smaller monitor sizes.
I can make up the subject because I think that option check / uncheck to show or not the avatars (as groups) would be appropriate.
Thank you for the work you do
