Valcav
I didn't to post it as a new Mod request, or as a feature request for vBForms...
1) As new mod: it would be nice to see it working together with vBForms
2) As feature request: could change vBForms to Version2 (and maybe change of name)
Here it goes:
I've got now for example: Project status
That is a template I've bought at Site Templates - Animated Under Construction - Twitter & Ajax forms | ThemeForest
at this point I need to make any change (evolution) into the file(s) itself, and need to re-upload them...
It would be nice to have something like this working together with vBulletin... and being able to edit the evolution from within vB...
And by making it work together with vBForms, I think you could get something really big...
Friendly greetings,
Valcav
Can you please be more specific as to what exactly it is you're wanting? I don't get it, I'm afraid :(
I've just updated Project status with a kind of example of the Project Dylan has been working on for me...
Now I had to change 2 files to change/add those informations to it & needed to upload those files to the server...
I'm going to try to explain what I'm wanting... (first of all, I'm kind of thinking this would be best for with vB5).
* Projects (project A, project B, ...)
* For each project you click, you can see a kind of evolution/progress bar (total bar) (normally on this bar it would only getting more)
* Tasks (with individual progress bars).
* Possibility to say if the following tasks (1 -> 4) are done, then the Total progress bar may add x% as completed...
* Versions (suspected release date, etc)
*Working with vBForms, would add a 2nd total bar (here it can go lower, for example when a new bug is reported):
-* Suggestions, bugs, ... (2nd bar (%) decreases)
-* When suggestions, bugs, ... are (set as) fixed, added, etc , then the 2nd bar (%) increases
-* can assigned to versions
(it's kind of hard to explain, it's a little bit of everything...) Key word? PROJECT I think... Just haven't found the best thing yet to (kind of) "log" my progresses on my project(s)
SORRY if I failed to explain it better...
