billcobb00
I downloaded vBNavTabs v1.3.1 [Lite].zip and got this at the bottom of all my styles. I submitted a ticket to BluePearl thinking the style was the problem and was told that it wasn't a style problem. They suggested that there might be a <div> </div> either added in the wrong place or is missing. This is sandbox forum I use before I install any mods to production.
This is the only MOD installed.
Any thoughts?
bill
Any thoughts?
bill
Check your email...
By the way thanks for fixing my IP...
bill
This has now been taken care of on your site, I had to merge the BluePearl customisations into the vBNavTabs template :)
I too am having style issues with this mod since 4.2. Would the same method be required for all non default styles?
#Update
Yep, compared the two, merged what classes i needed and now all is well!
Legacy vBNavTabs
