Anony999
I quite like the sound of post bits but can you give a little more info on what you can do with it and some screen shots would be good
Thanks
You can see it in action on this site, and you can try the Lite version (which also has screenshots attached) from our Lite Downloads area :)
Is it possible to put in tabs text and graphic of another mods (vBExperience bars and points, Point market system - icons...)
Most likely is not good enough answer :p
I must know that before buying. Yes or no? ;)
I know that answer is yes for one that know programming etc... but I want to know is ordinary copy/paste could be possible
You could always try the Lite version and see if copy/pasting works.
It's sadly impossible for me to guarantee that it will work with every custom mod, which is why we put out a Lite version :)
Additionally, you can post in their support threads requesting automatic compatibility with PBTabs, the code for how to do it is in the postbit_display_complete.php of mods like APTL, AUT, vBAA, vBShop. Helping to raise awareness amongst devs helps both us and yourself out :)
5K
Legacy Postbit Tabs
