Question I feel a bit lost here with Vbcredits and Vbshop intergration...
Haltech
Ok, i generally have no issues installing and configuring mods... however, with both vbcredits and vbshop, im a bit lost with its integration. Now i know a manual isn't ready, which would make life easier for all of us... So, anyhow, i decided to use credits as the currency.. I disabled the default points that vbshop was using and pulled the table credits_currency when i set up a new currency. I updated all of the accounts and updated the counter for transactions. I see on the toolbar, the currency tab showing the credits which is good. However, how the hell do you xfer them to the bank so you can make a purchase from the shop? Id appreciate any help with this. Thanks
Darkwaltz4 will answer ou as soon as he can, he is in the process of moving, and has limited time to get on the site right now. Thanks for your patience in the matter. :D
From what I understood you want to add Credits as a currency in vBShop
here is how you do it
AdminCP --> DBTech - vBShop --> Manage Currencies --> Add New Currency
Title: What you want :D
Description: What you want
Active: Yes
Display Order: Your choice
(Important)Points Table: user
(Important)Points Column: credits
Can Bank: Your choice
Can Steal: Your choice
All others settings are your choice too :D
Your table is wrong
And they don't need to be in bank to be usable in the shop
Bank is mainly for interest and protect from thief depending of your settings
And then you configure the shop and select this currency on item configuration :D
Bitchen, that did it. I looked at the tables int he DB and couldnt figure out which one it was.
Darkwaltz4, is it possible to make a plugin that will give credits to people who actually donate to my forum using AWCoding Donation mod?
I actually just talked to the guy who makes that addon and showed him to the vbcredits API, and he said he would take care of it :)
Legacy vBCredits II Deluxe
