Tech Dave
after installing this and trying to run the setup i get this error in my admin :-
Fatal error: Class 'vb_optimise' not found in/home/craftyca/public_html/includes/adminfunctions_options.php(634) : eval()'d code on line 56
i have installed it on my test site 4.1.10 and it worked perfect.
the file error i have checked and there are no differences in the file.
what would be the problem
many thanks
i have installed them in correct directorys,
i checked 10 times,
1 to admincp
1 to includes/xml
and the other is main root folder vboptimize folder.
followed exact same rout as i did on the test site.
---------- Post added at 23:28 ---------- Previous post was at 23:17 ----------
i have gone to check on firefox and its showing as setup, so google chrome must have a refrews issue
