nocomp
hi,
i wanted to try your mod, but when i go to the admin dbtech - settings, i get this error
Fatal error: Class 'USERTAG' not found in /home/[path ***********]/forum/dbtech/usertag/actions/admin/forum.php on line 26
any idea of what could be wrong?
best regards
We've seen this happening on forums that have the i.s.s.w "Security" product installed. If not, please try disabling all other plugins running on the admin_global hook and re-enable them one-by-one until you find the culprit :)
hi,
we do not have this plugin installed, it s a fresh installed forum set for a migration smf to vb, the only plugin installed is yours
Have you uploaded all the files to their correct folders? Drag and drop the contents of the upload folder to your forum folder.
yes i did and import xml file, no issues or error or warning what so ever, that s why i was surprised to see this error in settings, cause other menu in admin for option works.
but over all the pugin is not working
I will reply to the PM if I need more information, or post back in this thread when it's been resolved.
I'm unable to replicate this issue on your site, I can browse all areas of the AUT admin areas without issue.
hi,
i ve fixed the issue was coming from a wrong path setting in config.php, quite weird that all was working even it pointed to a wrong directory.
nvm when in a message i write Testnocomp i don t see any notification in user testnocomp email , di di missed something?
best regards
Legacy Advanced User Tagging
