cricfire
So, when the mod was enabled, the double posting was happening almost EVERY time. But the error is worse for Administrators and Super Moderators - because they are exempt from flood check (30 seconds). However, normal members also had the issue but only sometimes.
Another mod of relevance that I have installed is - Doublepost Prevention - Doublepost Prevention - vBulletin.org Forum
We have that mod as well and none of our staffers have the issue (to my knowledge). Unfortunately since it's not something I can reliably reproduce, I'm not sure if I'll be able to fix it :(
You could try disabling all other mods and seeing if the issue persists - if so you can try enabling them one at a time to find the issue.
Okay! I will try to disable other mods. Let's see...
---------- Post added 18th January 2012 at 20:46 ---------- Previous post was 21st December 2011 at 23:56 ----------
I tried disabling mods - didn't help.
Then, I went to vBulletin settings and selected "Disable All Problematic Ajax Features" and since then I have had no problems. What do you guys think?
---------- Post added 22nd January 2012 at 00:21 ---------- Previous post was 18th January 2012 at 20:46 ----------
Bump? :$
There's nothing more we're able to do unless we can reliably reliably reproduce it, sorry :(
My thread is closed, so I use this thread.
I think that I found the reason why sometimes I see double post (for me it is very rare occasion). But, when I say that I see double posts, this doesn't mean that there are actually made double post, they just look so on the screen.
Thing is, as I understand it at this moment, we have two ajax systems at the work when we use quick reply.
First system is original vB, it uses ajax to just append new post when we use quick reply. Post just "appears out of nowhere" in thread.
Second system is from Ajax threads, that works similar to this system, posts appear also "out of nowhere".
And, if by any chance both system work at the almost the same time, there you can see double post, but as I said, it doesn't seem that there's actually double post in DB, only on screen. If thread is reloaded (standard way), there's only one post. So, this is, at least for me, just visual problem and not that big.
As it is connected with "synchronicity" of these two things, having Ajax thread that refreshes very often can cause more double posts. I use 10 seconds on my site. If you want to try test it some more, try with 1 second and write with quick reply, I'm sure you'll be able to catch at least few "double posts".
Of course, I'm not 100% sure, but I just had one and I think that I saw "blink" of Ajax refreshing my screen, that lead to double post.
Hope this will help you to understand what is going on and even maybe correct it, although this is not too big of a problem for me.
Legacy AJAX Threads
