1) hi.....i before this i use vbexperience4 and i uninstalled it after i use vbactivity pro
the problem come when i installed vbshop pro and i get this error everytime when i submit new thread and post
Database error in vBulletin 4.0.8:
Invalid SQL:
UPDATE user
SET vbexperience = vbexperience + 1
WHERE userid = 1;
MySQL Error : Unknown column 'vbexperience' in 'field list'
Error Number : 1054
Request Date : Tuesday, December 7th 2010 @ 08:57:29 PM
Error Date : Tuesday, December 7th 2010 @ 08:57:30 PM
Script : http://www.cutimalaysia.my/newreply....ostreply&t=917
Referrer : http://www.cutimalaysia.my/database-error/t917
IP Address : 175.138.89.208
Username : Mr. Tuah
Classname : vB_Database
MySQL Version : 5.0.91-community-log
i didn't get this error after i uninstalled this plugin vbshop
how to fix it so that i can use vbshop pro again??
2) can you give comparison benefit when i using vbcredit deluxe and vbactivity ??/ i'm still confius
Change the Points Field setting to dbtech_vbactivity_points and then turn off the points accumulation setting in vBShop directly beneath that setting.
vBActivity is primarily an Achievement / Award / Activity tracker, whereas vBCredits is a points mod.
Small piece on the differences:
vbcredits is a much more powerful points system - it lets you have and manage multiple currencies, has donations, gifting, members purchasing credits via paypal as of version 2 (currently in open beta for all pro customers).
vBActivity is much simpler as a points system, though it has comparisons and targets for users, as well as an in-depth awards system which, we are told, has more features than the popular Yet Another Awards System modification.
The two can be used together quite harmoniously and there are tips on how best to combine them throughout the forums ^.^
Your best bet would be to download and try the Lite verisons to compare though - there are lots of differences depending on how you are going to use the mods - too many to list!
Cosmic
but if you didn't make better and clear comparison how can it help me to make decision to use this another plugin
If you are unsure you could install the Lite versions of both and try them out =)
The differences are too many to list, as they depend on exactly what you want to use the modification for. If you let us know what you want it to be able to do, we can recommend the best option based on that - alternatively they both work together just fine as well.
Cosmic
Legacy vBShop
