Sicilian
I've just found that sounds are not working for any members on my forum.
Sounds have been set to pop.mp3 and sounds have been turn on, Enable Sounds has been set to yes.
If you are having problems with sound, please follow this check-list:
1)
Did you select a sound to be played in the Instance Manager?
AdminCP -> DBTech - vBShout -> Instance Management -> [Edit] -> Shout Sound / Invite Sound / PM Sound
2) Are sounds turned on?
AdminCP -> DBTech - vBShout -> Settings -> Enable Sounds
3) !!!Pro Only!!! Are sounds turned on in the UserCP?
UserCP -> Shoutbox -> Shoutbox Settings -> Shout Sounds / Invite Sounds / PM Sounds
4) Is the QuickTime browser plugin installed?
QuickTime Plugin- Please note that you need to restart your browser after installing the plugin.
5)
Does it work in other browsers?
If you only have one browser on your computer (Internet Explorer) you should try out Firefox.
6) Is the following text present in the source of the page: <embed ?
Right click -> View Source -> Ctrl+F -> <embed
If this is not found, and all the above steps are completed, then you may have an out of date template. Please revert any customisations to dbtech_vbshout_shoutbox
If none of the above steps fix it for you, then it's a browser issue that we are unfortunately unable to assist with.
