Mick
Hi Mokonzi,
When I am logged into the forum the £ pound sign looks like a £ but when I am logged out and viewing as a guest the pound sign looks like a sort of diamond question mark
Have a look at this attachment... strange one?
Cheers
Mick
HTML Character Set = ISO-8859-1
MYSQL Collation = latin1_swedish_ci
I checked my database in phpmyadmin, and all tables are latin_swedish_ci
Cheers Mokonzi
Mick
I've found some comments that suggest it could be the DOCTYPE... what do you have running on your pages?
£ sign not displaying correctly - any suggestions? HTML forum at WebmasterWorld
Some of the alternatives in there work fine. You can use £ to replace the £ sign and it will then always get encoded correctly, but as pointed out, it does more than double the bytes used to create the sign... so it depends on what you want to do.
From what I can tell this doesn't seem to be an issue with Classifieds. But we'll talk through the issue here to be doubly sure that we can find a solution for you and in case it comes up for anyone else.
If you can post the DOCTYPE for the page when loaded as a user and the one as a guest we can see where that might lead us. :)
Hi Mokonzi,
Thank you for looking into this for me that is great.
Logged In:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" dir="ltr" lang="en" id="vbulletin_html">
Logged Out:
It looks the same to me?
Looks the same to me as well... hmmm.
Does using £ work properly for both guests and regular users?
This is quite odd now.
It would seem that this only happens on the forumhome page (forum.php) and also on the featured items advert.
All other deployments of the advert are ok?
The £ seems to work though.
Regards
Mick
I have these further details Mokonzi,
Any clues here?
I bolded one line that might be of interest???
PHP
PHP-Version 5.4.22
PHP Server API fpm-fcgi
PHP Safemode Off
XML-Extension Yes
cURL-Extension Yes
iconv-Extension Yes
mbstring-Extension Yes
default timezone UTC
MySQL
MySQL-Version 5.5.34-MariaDB-log
character_set_client latin1
character_set_connection latin1
character_set_database latin1
character_set_filesystem binary
character_set_results latin1
character_set_server latin1
character_set_system utf8
collation_connection latin1_swedish_ci
collation_database latin1_swedish_ci
collation_server latin1_swedish_ci
have_query_cache YES
query_cache_limit 524288
query_cache_min_res_unit 2048
query_cache_size 134217728
query_cache_strip_comments OFF
query_cache_type ON
query_cache_wlock_invalidate OFF
Legacy DragonByte Classifieds
