overhere
I have purchased the life time license + branding free for the Live Feed module.
But, after installation, what we now see on our website doesn't appear to be the same as what is visible on the DBtech website. Please see the attached photo 'untitled' of comments in live feed on the DBtech website. Here, you will see the actual comment and features like '0 comments' and 'favourite' etc.
But, if you then look at the comment made by mistry in the live feed on my website, attached file 'mist', this just shows the comment it self and nothing else, and mistry can not also comment on admin's post here? Basically on my website there is no 'comments' and 'favourite' features visible?
Please advise what the error may be and/or if there is something during installation etc. which my developer may have missed on.
Thanks,
O.H.
Check vbAdmin --> DBtech Live Feed -->Settings --> DragonByte Tech: Forum Live Feed & User Wall - General Settings
Enable Previews
You can use this setting to globally enable / disable previews for all content types.
--> Yes
(Pro) Recent Entries
This setting controls the number of "Recent Entries" displayed on the static list.
The "Recent Entries" page is designed to allow members to catch up with older entries that have been cropped off their view.
0 = Disable the "Recent Entries" page
Default is 100
Hold on will update about the Comments :)
---------- Post added at 14:16 ---------- Previous post was at 14:01 ----------
Thanks,
O.H.
Check to see if the dbtech livewall_pro contents where uploaded to the server.
The comments and favourites are in the livewall_pro folder.
Maybe upload the whole package again.
The only two possible reasons why the Favourite and Comments links are missing is that you may have installed the Lite version previously, and forgot to re-import the product .xml file when updating to the Pro version, or you have the Comments Max Length set to 0.
I'll correct it so that comments can be disabled without disabling the Favourites link in a future version :)
