Bug Issue with Forum URL Rewrites with apostrophes in title
bzcomputers
It appears that apostrophes / single closing quotes in Forum Thread titles are being rewritten as "a".
Examples
Title:
Carnival Introduces New Marine-Themed ‘Camp Ocean’ Children’s Program
URL:
carnival-introduces-new-marine-themed-camp-oceana-childrena-s-program
Title:
Carnival Introduces New Marine-Themed "Camp Ocean" Children’s Program
URL:
carnival-introduces-new-marine-themed-camp-ocean-childrena-s-program
How would I go about getting DBSEO to remove all apostrophes from titles and make any trailing "s" after an apostrophe part of the original word?
Does it work if you replace the and symbols with ' (there's a difference that you may not notice unless you look really hard)?
If yes, try adding the and symbols to the Stopwords list.
If no, let me know and I will debug this further (on your site if necessary) :)
Yes, swapping out and symbols for ' gets the results I was looking for, as far as the ' being filtered out.
Example:
Carnival Introduces New Marine-Themed 'Camp Ocean' Children's Program
carnival-introduces-new-marine-themed-camp-ocean-childrens-program-2474/
What's the best way to go about getting that to be the default sitewide for titles?
I tried putting and in stopwords but it appears they may already be getting processed prior to the stopwords code because it appears not to change anything.
Try removing them from stopwords and adding them to the Custom Character Filter setting, like so:
If that doesn't work, try
& #2018; => '
& #2019; => '
(Remove the space after & )
Hopefully one of those will work :)
Thanks, the first option worked well.
Added this to the Custom Character Filter:
...for those of you who may not have come across this issue to date.
This issue arises when/if you have any automated posts (i.e. RSS Feed posts) where the title contains a single quote or apostrophe that looks like or (notice the curl to them). This can also happen if copying text into the title box from another source that already contains one of these curled apostrophes / single quotations.
If you are manually typing in the title box you will not encounter this issue because all apostrophes / single quotes while typing will appear as ' (notice no curl) and these are already automatically removed during url rewrites.
Some Office apps and also Mac OS X tend to default to those kind of fancy apostrophes rather than the good old straight apostrophe.
Hi
I have Titles with simple quote : ' (no curl)... I would like them to be replace by a dash.... as it was the case in my old VBSEO configuration
For now DBSEO replace this simple quote by nothing so separated word are "stuck" together
Eg : "l'amour" will be replaced by "lamour" in the URL
I would like it to be replaced by "l-amour"
in my Custom Character Filter I have added :
But the simple quote is still removed and not replaced by a dash
Any idea?
txs
Olivier
This cannot be done as it would cause data integrity issues when resolving URLs that need to be resolved based on the text rather than IDs.
As this topic is over 1 years old, I'll close it :)
Hello bzcomputers,
