Hi Ozzy, for some reason even after reaching over 100% goal the sideblock bar color doesn't update to full. The main goal bar on the forums is updated to full.
Did you clear any caching systems you are running like vBOptimize? I was able to reproduce the issue on my dev site, and the fix I did solved the issue.
EDIT: I see it is happening on my dev site again, I will dig deeper.
