MARSH
When I updated to the latest version of the editor tabs we lost all of our tabs on both the quick post and advanced post options.
If I go into user CP all of the features for seeing the icons and adding favorites work fine.
I've verified all permissions are correct and tried applying the various tabs.php files that I have found here on the site.
Suggestions?
Reverted the vbeditortabs template and its working now. I only did it in the main theme, so you may look at if its needed in any other themes.
It wouldn't have been a new template issue, as a new template would have overwritten the old, unless the old had been edited. So not sure if you had edited the old one or what. By reverting it, it should now match the current version of the product.
Legacy vBEditorTabs
