Have you set up the settings in Instance Management interface and edit the "Quantity" settings to a number greater than 1 for the content types you wish to show on the CMS?
I assume in Instance Management you have the setting CMS Integration Active set to Yes?
Hmm ok then I am at a loss, you will have to wait for the dev to have a chance to answer you then. :(
It looks like its an issue with the "ALL CATEGORIES" selection for the CMS. I just selected all the categories instead of using the single "All Categories" selection, and it works fine. Go ahead and remove the permissions you supplied for troubleshooting.
Ok it was working and not it isn't. I want it to display all the sections under CaneHunt but not CaneHunt. I don't really use the categories so all of them can be selected.
Appears to be working. Not sure if it was originally when I went to the page or not, as you moved where you had it (from the top to the bottom of the page), so I was messing with a bunch of settings trying to figure out why it wasn't showing at all. Finally I scrolled down and found it, and it was working.
Ok, something is really odd. No matter what options I choose for the sections, it always shows the same 4 articles. To try to troubleshoot further, can you please provide FTP access?
Legacy vBSlider
