Bug Menus for shout box in admincp don't work
karlos
Hi,
I was looking to purchase shout box, but first I wanted to test it out.
The actual shoutbox works great, but whenever I click any of the options in admincp, all I get is an empty screen:
Is this normal for the lite version? I thought some options were available. To be clear, if I click any of the following links:
Instance Management
Chat Room Management
View Banned Users
Command Log
Download Archive
Repair Cache
Notifications
Options
They all just give a blank screen as shown above
Regards
Karl
Please make sure display_errors is turned on in php.ini
You should also be aware of the fact that vBShout has not been tested on vB 5.1.9, and we have no current plans of developing any more modifications for vB5 due to the amount of crippling issues and flaws of that platform.
vb 5 is the flagship product, so its disappointing you won't be supporting it. New customers are going to install 5 by default.
Your blurb for vbshout also says its available for vbulletin 5.X, you might want to change that.
Unfortunately it's not feasible for us to support a product when they have no intention of supporting us in the creation of addons for it.
It is available for vB5, but it's in Alpha. It never left Alpha stage due to the fact that vB5 has been notorious for breaking backwards compatibility, so we cannot consider any of our vB5 products stable until they stop developing vB5 so the codebase settles down, so to speak.
Hello karlos,
This ticket has now been closed with the status Won't Fix.
