If you're reporting a bug, please use the "Bug" category when posting support threads.
I've adjusted your refresh timer back up to 5 seconds, which is the fix for this problem. It is impossible to fix the issue when you have it refreshing every second.
In a future version I will disallow any refresh timers lower than 3 seconds :)
Thanks...
I don't know how you organize this forum so sorry for the inconvenience.
How do I set this add on to specific forum?
Click the "Forum Manager" underneath the "DBTech - AJAX Threads" AdminCP header.
If you don't see it, set yourself to Super Administrator via config.php
I can see it but this "Automatic Updates Disabled" makes me confuse.
So when I check on the box which means it will Automatic or Disable?
What I can understand now is none of these boxes checked, it means they are all Automatic? When I check on the box it means Disable?
Thanks.
That cannot be done at this time.
For the future, please do not post separate issues in the same thread, it makes it impossible for our system to track separate issues. Thanks :)
Legacy AJAX Threads
