[resolved] display problem
Hi,
small problem display on every page I have put it in the Navbar the only concern that this on the forum showthread it appears twice?
Thank you for your help
Hi,
Varname For instance, if the varname is instance1 then the code to place in your template of choice is:
{vb:raw show.vbshout_instance1} instance1
