Kyle T
everything was working fine then all of sudden got this
any help?
That only happens if someone accesses the page before the mod is installed.
Go to your Phrase Manager in the AdminCP, do you see "DragonByte Tech: InfoPanels Phrases" as a phrasegroup? If yes, it's safe to ignore that.
If no, please re-import the XML then check for it again.
i cant my site wont load completely
Open your config.php and below<?php add this line:
So it looks like this:
<?php
|| # vBulletin 4.1.4
Then make sure all files are loaded to the proper place, and re import the xml, then remove the define('DISABLE_HOOKS', true); ftom the config.php
Legacy InfoPanels
