Footman
I do like this mod very much however I'd like to know a few things before I purchase the pro version, if it fits my needs.
1- Is it possible to place the "Like This Post" link and icon in the post control area next to the 'report post' triangle? I'd like to only have the link and the thumbs up icon and NOT the header.
2- Can I show ONLY the likes given and received in the postbit? I more than likely won't use the thank you's or the dislikes.
3- Does this mod integrate with other point systems? I'm using UCash as it was simple enough for my needs.
Thanks,
You can place the buttons next to the "Blog This Post" link, but the header will still display since that houses the "x clicked Likes for this post" blocks.
v3.0.3 has the option to control what postbit stats you want to show on a per-button basis :)
This mod doesn't integrate with any points systems of any description, sorry :(
I'm blind... I don't see the "blog this post" link :( Is there a screenshot somewhere of this placement so I can see it?
Most excellent, thank you.
That's too bad for me. However I assume it will still work but without the ability to give points for likes etc. Is that correct?
Of course it'll still work, and you can always give or remove Rep points for button clicks :)
Ah! I don't have 'blog this post' enabled on my forum so I didn't see it. Is there a screenshot of how the placement of the like button and the header looks there? If not no biggie, just trying to get an idea.
Also, if I understand you correctly I can set the like button to give rep points to the default vB system. That's those little green boxes under the username right? So it will just be more of a status thing, which would be just fine also.
Excellent!
if I'm just using the like button, I assume the header panel below the signature will only show the likes info and not the other parameters.
