Jeremy
What is Paycheck? I'm guessing you get it just for logging in that day? Is it once a day? Or do you get it whether you log in or not?
Also, under Available Events, the Action Row - What are the Applies, Moderate, and Select columns for?
Paycheck happens for the users you target with no special requirements. You can change the frequency in the action specific config.
Applies is just info on the usergroups/forums that apply to that event. Moderate will cause all transactions for that event to be moderated when someone earns it. They wont actually get the credits from it until you manually approve it via the browse and moderate transactions page. At the bottom of the available events table is a dropdown with the functions you can perform with the events marked as selected.
i've got the problem that there isn't a dropdown and i have to moderate 123289 transactions.
is there a way to mass moderate all of them via mysql or any other way?
In newer versions you don't need a drop-down. You can use the tickbox next to "Moderated" in the header to mass-untick all the transactions and then click Next Page to save it.
Unfortunately it's not as simple as being able to execute a MySQL query :(
sorry, but that doesn't seem to work. when i come back to browse and moderate logs the next time, all the transactions are still shown and checked again :(
EDIT: Nevermind, I see the issue. I'll post back when I have updates.
Update: It works if you click "Update Transactions" and not the "Next Page" button. Pretty unintuitive interface design, IMO. We'll be sure to fix that when we re-design the mod for a future update :)
In order to allow me to mass-update transactions, please edit your php.ini and set max_input_vars to 100000 or higher, then restart your Apache server.
Legacy vBCredits II Deluxe
