Haywire0311
So, I've implemented both vbShout Lite and vbOptomize Lite on my site and I'm considering upgrading to the 3 month license of the pro versions for both but I'm hesitant right now. Ever since I installed vbShout, my site has been timing out like crazy. There's periods during the day where I can't go on for a few hours and it's frustrating as hell. I keep getting timeout errors that are associated with vbShout and when I do webpage speed tests, the hang up is usually due to vbShout or Infopanels. I'm close to going back to VSA Chat but I like vbShout too much and so do my members. I also like the rest of DBT products and have already purchased one of the pro versions for one product.
So, my two questions before I go ahead and spend the money for vBS and vBO are:
1) Will vBOptimize Pro be able to help with the timeout errors? To see an example of the timeout or if you'd like to perform a webpage test to view the hangups, my site is www.m3orpg.com. I know there are a couple of other things that can be done to stop the problems but I (unfortunately) have godaddy as my hosting provider for a year so I can't change the max timeout settings in the php.ini file. And I don't know how to do CSS Sprites so that is out of the equation. Besides, those aren't holding it up as much as Infopanels and Shout are. So, if I purchase vBO Pro, will it help reduce these timeouts?
2) If I purchase it and the problems persist, is it possible to get a refund?
That's it and hopefully going Pro will help.
Thanks,
Bob
Thanks,
Bob
