OlijO
After posting this thread
http://www.dragonbyte-tech.com/thre...e-vBCredit-vBActivity-Lite-version-Paying-job
I receive some proposal like 170$ to do the job (developermal).
So i decide to setup myself, i've install vBactivity and it's ok.
I install vBCredit and have a last problem :
So when a member post he receive the credit without problem.
When he receive an infraction he spend credit ok.
Now i would like to setup an Activity Amounts Configuration for this action :
Post a new thread in the forum X spent X credit.
I test with this configuration :
-Action : Thread.
-define forum (all)
-define user : member
-Thread AmountAwarded whenCharged every time this action occurs. : 5
-Thread Negation AmountChargedAwarded when this event is reverted : 5
-Word AmountAwardedCharged for each Word along with the Thread amount whenevery time this action occurs. : 1
-Word Negation AmountChargedAwarded for each Word along with the Thread negation amount when this event is reverted. : 1
Save
-Charge is notched
After i test with a test account to post a thread in the forum who are defined before and the credit is not spent, but the earned credit yes, what's wrong ?
Thanks you for answer
sorry, i think i accidentally marked to close the thread at the bottom of the admin quick reply :-/
Ho ok :) sorry, since the beginning i've got problem to setup this mod and i thought this was another problem started !! :d
So to answer to you question, yes it's the last version for vbCredit and vBactivity :)
Just test with another forum and the lite version, and i have the same problem, so it's a bad configuration or a bug i don't know, here is a image of the configuration, perhaps this help you...
Found the problem !!!!
I setup this options :
Win 10 credits to make a thread for ALL forum
Pay 5 credit to post in ALL forum
I think only one action is authorized, because when i setup like this
Win 10 credit to make a thread in the forum X, Y except Z
Pay 5 credit to post ine the forum Z
That works except this thing :
I setup thread point win to ONE forum the forum X
I setup thread point pay to ONE forum Z
Result, i win point in all forum even the forum Z
lol found the problem :)
So apparently we couldn't do this
-Category X
---Forum X : receive X credit to post a new thread
---Forum Y : pay X credit to post a new thread
This doesn't work, but when i do :
-Category X
-Category Y
This configuration work, so am i wrong or not ?
The category shouldnt matter, it depends on the specific forum. the system works by gathering all of the events together that apply to that situation, and awards the best one.
so, if you are trying to charge in one forum and award in another, make sure the one for awarding selects everything EXCEPT the forum you are charging in, or the system will consider it better than charging and award instead.
does that fix it? Someone else had a similar problem which is why I didn't have a solution for you yet, but this might shed some light on the whole thing - which would then be working as designed.
Confirmed with another user that this was indeed the reason behind it :p Carefully set your applicable forums, and it should work as expected.
Legacy vBCredits II Deluxe
