Question updated needed: for not charged user for edit their own threads
moviekase
URGENT: updated needed: for not charged user for edit their own threads. can you please update this mods not to charge user for edit their own threads since it's not right to charge them again.
thank you
This is already a feature. Please find & use the "Negation" setting in the Thread and Post events to utilise this feature.
The "Negation" works only when user had enough money to edit because they would charge first and give back the money after
example: if the threads cost $10 to post ..and now if user wants to edit his/her threads.. they need to have extra $10 to EDIT their own topic since "Negation" would first charge again $10 and give back $10.
Need UPDATED : hope for user doenst need to be pay first $10 and get back $10. can you have this update. .URGENT
thank you
The "refund" happens before the new charge. In either case, you can also alter the currency settings to allow negative numbers but display 0 :)
1. It show
"Spent $10.00 Credits" first
then
"Earned $10.00 Credits" after
if the user have only $9 .. it wouldnt allow them edit the topic which cost $10 or Negation $10 in the setting
so this step doesnt work
i took your advise " in the currency settings" i've set "Show 0 but keep negative" or even "Allow negative display" ..it still doesnt work.. the error message said "Sorry, you need $10.00 Credits to post this thread."
can you fix inside the code alittle to twiste it around for negation .. Earned $10 first before Spent $10?
best and thank you
The reason why the transaction list shows that way is because the two events are being queued in a semi-random order, unfortunately there's no easy fix for that.
It would require a complete re-write of the mod, which is something we have done for the XenForo version, but currently it's not feasible to back-port this to vBulletin just yet.
Sorry I couldn't be of more help :(
Would you able to make a little change for any event has "negation" set ups.. and would have Earned first and Spent after? instead of Spent action first and Earned After?
please and thank you
Hello moviekase,
Legacy vBCredits II Deluxe
