Dutch_Boy
Hey,
Some of my members having trouble with the template layout after installing postbit tab.
As you can see on the picture the text is placed in a other place :S
Hope you can fix this problem.
Kind regards,
Dutch_Boy
Please disable views one by one and let me know which view is causing this issue, if any.
So took some time but here they are:
Activity Stats tab:
DragonByte Tech: vBActivity - Activity Stats
DragonByte Tech: vBActivity - Achievements
DragonByte Tech: vBActivity - Awards
VbShop tab:
DragonByte Tech: vBShop - Points Display
DragonByte Tech: vBShop - Gifts
There offline and template problem is gone now. When i turn one of them off then the template is messed op again.
Also another little thing:
http://www.icked.nl/awards_issue.png
Did you customise any PBTabs templates or any of the postbit templates for those mods?
If it works on the default skin, then it must be something in your custom skin causing it.
If you PM me with an admin login with can admin pbtabs and can admin styles, I should be able to figure it out :)
I've been unable to confirm this problem on IE8. Sadly I do not have earlier versions of Internet Explorer available for testing.
Doubtful, it would only happen if there was some bad HTML, like say opening a <div> tag and then not closing it properly.
Legacy Postbit Tabs
