Question swicht postbit tab - not work
Website
http://www.ForumViaggiatori.com
Product version
1.1.4
Forum version
vBulletin 4.2.x
#1
I'm also trying this mod, but not by clicking on the switch points between the tabs
what could be your problem ?
Thanks for support !
Belazor
Staff member
Owner
Developer
You have multiple older versions of jQuery running @ your site, you need to upgrade them all to 1.7.2 in order for our mods to work properly :)
#3
sorry for the question
jQuery updates on vbulletin (I do not know how), or is to be made on a configuration server hosting?
thanks for support
Belazor
Staff member
Owner
Developer
You will need to edit your vBulletin templates. If you search for "jquery" in all templates, you'll find all references to jquery in your templates. Find the ones that have a lower version number than 1.7.2 and edit them to read 1.7.2, then save the template. Repeat until all instances have been modified :)
#5
ok, I'll get right to edit all templates to check if it works.
Just one question, when I find a "jquery" version lower than 1.7.2, which I enter?
1.7.2 or above (example 2.1.4 ?)
thanks
Regards
#6
perfect ... now work the switch tabs postbit :D thanks, thanks, thanks !
I was hoping that this would help me to solve the problem (I have in a long time) on mod "Advanced Post Thanks / Like" :(
(clicking on the buttons nothing happens)
Regards
Belazor
Staff member
Owner
Developer
First, could you please double-check the user group permissions in the Manage Buttons interface to make sure the "Can Click" permission is given?
Next, can you check the error console in your browser (F12 on most systems/browsers) and see if you notice a JavaScript error related to the Thanks mod?
Company Information
Staff member
Company Info
#8
Hello ClaFV,
Postbit Tabs
