also why has some posts got the buttons and some have not Your posts you will not see the buttons
when i quote it says this even know i said thanks to it That is to protect the original content, or everyone could see it.
but i dont see it shows hidden and when i test it on my forums does not work them same does not show it hidden when quoted
[HIDE]Check your permission settings in DBTech - Post Thanks/Forum Manager, you need to set up which forums it works in.
Also once that is done you need to wrap the content with the hide tags and require thanks or likes in order for it to work.
Also it must be done in advanced not quick reply.[/HIDE]
i see the options when I make a post do i need to high light the text first or something as i did this and still will not work
In order to have the post hidden you need to wrap the content with [HIDE*][/HIDE*] with out the * and then click on require thanks, likes or dislikes to see content.
[HIDE]I am almost certain you may have the permissions set up wrong, as DBT has had no other reports of this not woking, and as you can see it is working on here.[/HIDE]
I will not be able to do it tonight, but if you pm me a admin account and ftp info, just incase I need to reload files, I will have a look at it tomorrow when I get home from work.
Ok I received the pm, I will look into it tomorrow and report back in this thread, stay tuned. :cool:
4K
