Bug Since 1.0.2 the forum selection does not work
angus
After updating to version 1.0.2 there is a problem with the forum select option with the forum slider.
I selected two spezific forums to display threads and set the latest threads quantity to 5.
But instead of showing 5 threads from the selected ones, 5 latest threads from all forums are shown.
It seems that the setting is ignored.
Ok, I'll take a look at it. Thanks.
---------- Post added at 09:46 ---------- Previous post was at 09:09 ----------
Got it. I still don't have FTP access to upload a fix, but its a fairly easy fix to make.
In {forum}/dbtech/vbslider/actions/widget.php, on or around line 64, find:
foreach (array($forumids) AS $forumid)
and replace with
foreach ($forumids AS $forumid)
That should fix it right up.
Legacy vBSlider
