MySaltyReef
Hi There,
Really happy to come across this product, very useful to our forum, so must say thank you very much.
However am having a problem regarding the layout of the review product. When you click on add the review, It is out of position and alignment of text boxes incorrect. Would appreciate any assistance
You can probably use CSS to correct any such issues, or edit the dbtech_review_review_create template :)
Thank you, but sorry just a hobbiest that owns a forum, and not knowing such coding and usually rely on readme's and links to info to get by. We have many Dragon byte hacks installed on our forum as they are truly are very beneficial to us. Would you be so kind to put it in layman's terms
I don't know what the problem is (no screenshots) so I can't really be more specific just now.
Is that Internet Explorer 6? If so, it's too old for us to be able to support. Are you running the latest version of Safari?
Have you tried Firefox 29 or Chrome?
Yes Sorry IE7 i was at work testing and only have that version installed bit outdated :RpS_biggrin:, but regarding safari have attached pics as well, and using version is 5.1.7, have ask seen the same on firefox and chrome
Can you ensure you're viewing it on an unmodified skin, and also try disabling all other products?
It seems like another mod is causing this issue by having incorrectly coded HTML.
Not unless you use a 3rd party product manager, though I can't say I know of one that lets you mass disable products.
Legacy DragonByte Reviews
