Bug Java issue
Dantro
Hi,
I have installed the product fine but when opening tab the map appears for so long then come up with Java error, can you assit with this matter?
Regards,
Dan
Hi there,
Can you please provide the actual error message? Without the error message I will be unable to assist you.
Thanks!
Hi, i comes up with the following error:
Sorry! Something went wrong.
This page didn't load Google Maps correctly. See the JavaScript console for technical details.
The problem is most likely your jFeed modification, its version of jQuery is too old. Could you please try removing this modification then try again?
Hello Dantro,
Legacy Member Map
