Nirjonadda
Forum and SubForum Rewrites does not work , please check on this issue.
Does not work: /f45/f49/f53/ ( Sub Forum View)
Work : /f45/f49/f53/156391-christina-aguilera-photoshoots-2.html ( Thread View )
Are you referring to the URL structure redirect? If so, then this is another limitation similar to the one reported previously. Unfortunately, not all structures can be redirected seamlessly.
If i change any Rewrite Rules than old URL are dead and the URL not working get ? Please can you do for this Redirect to Home Page ?
Most URL formats will redirect to the new content. However, some formats can't, most notably if the old URL format matches another, current URL format.
There's nothing we can do about this, unfortunately :(
I think you are not understanding me ? why not working are same URL is /f45/f49/f53/thread_title , If i remove thread_title why not open forum/subforum ? As you are this MOD Developer and you know best , I just put my Suggestions.
/f45/f49/f53/ Not working without thread_title ?
/f45/f49/f53/156391-christina-aguilera-photoshoots-2.html (with thread_title working)
When you remove the thread title from the url, the rewrite will start going by the "Forum URL" setting not the "Thread URL" setting. Your "Forum URL" setting must match your "Thread URL" in structure in order to do what you want it to do.
It would be best if you showed us your "Forum URL" setting also.
