Legacy Advanced Post Thanks / Like Pro - HIDE code - Require Thanks to see content - New thr
orion02
I have bought MOD "Advanced Post Thanks - Like v3.2.7 Pro LIFETIME" and installed it on my forum.
This MOD is really sophisticated, I have to say. As English is not my mother language, it took me a while to go through the settings, but this is not a disadvantage of the MOD, of course. It may just happen, that I haven't discover all the features of the MOD.
IMHO the HIDE code doesn't bring such a comfort I was used to with "vFCoders - Hide Hack v4", which I had a bit customized. Please do not take it as unnecessary criticism. I know that most of the other forums doesn't use the HIDE code in the same way as mine.
I will ask for advice with three separate problems with HIDE code and I will open three separate threads for them.
I strongly hope, you will help me to set up the HIDE code the way I need it to work.
So second problem is that I do not know how to set the "Require Thanks to see content" as default ticked during the new thread creation.
The best solution for me would be to add this choice into the ACP, as "ACP => Manage Buttons => Thanks, Likest etc."
Default Button:
Content If yes, clicking this button will be required to see content between [HIDE] tags when making a post from Quick Reply.
I would prefer the ACP setting as it is on "Quick Reply", but I will be glad for any advice how to solve it.
Thank you in advance.
PS:
question # 1 - http://www.dragonbyte-tech.com/f37/...e-pro-hide-code-administrato-15468/#post81302
question # 2 - http://www.dragonbyte-tech.com/f37/...e-thanks-see-content-new-thr-15469/#post81303
question # 3 - http://www.dragonbyte-tech.com/f37/...code-post-requires-you-click-15470/#post81304
When people post new threads, the boxes are available, vs the quick reply where they aren't there. That's the reason :)
I am sorry, but you probably misunderstood my point.
I know that the boxes are available while new thread creation and they are not for quick answer.
But what I need is, to have the box "Require Thanks to see content" in "Miscellaneous Options" ticked (selected) as default. That means when any user of my forum will create a new thread, he will not need to tick (select) anything (or lets say - check the box) and the content of his post will be hidden automatically.
I hope it is more clear now and thank you in advance for your help or advice.
3K
