cykelmyggen
Hi
Installed the 3.0 version but I can't make this to show on either CMS(Widget) or on Form. Followed the guidelines provided in the doc side.
You have turned off all content display in the slider, and there is no custom content created for the slider either. For that reason the slider does not display.
Please use the Instance Management interface and edit the "Quantity" settings to a number greater than 1 for the content types you wish to show on the CMS and the Forum.
Hi there,
i have the same problem but i created default content and everything else. Ill will send u an PM with all sensitive information...
I am also having the same issue. The lite version was working ok but I uninstalled it and bought the pro version and now I am having problems. I will PM you with my details.
Thanks!
I figured it out. I had the "Enable vBSlider in any Global Template on the CMS" enabled when it should be disabled.
Legacy vBSlider
