Question Installed see settings in Admin CP but not on Forums itself
AngelOfHype
I've downloaded and install vBSlider but having issues. It shows in the product install, and shows well in admin CP i set it all up fine no problem when i click on main Forums it dosn't show the slider i set it with the right Forum links but there no slider on the forum itself is there a config i have to edit or a file to make it show on my main forum
Running Vbuilletin v4.2.3 patch level 2, PHP Version 5.5.36
AngelOfHype
GreatHabbo Founder
GreatHabbo » Coming Soon!
Did you edit the slider and set at least one content type's display counter to a number higher than 0?
Can you please try disabling all other modifications and make sure you're viewing this on a default (unmodified) skin to eliminate any conflicts or skin issues?
Hello AngelOfHype,
Legacy vBSlider
