IcEWoLF GoodApples Freekoid Valcav Mokonzi bszopi
The new version of vBDonate is available in your Customer Area now.
Follow the below steps before upgrading!
1) In the ACP go to Plugins & Products - Manage Products
2) For the product DragonByte Tech: vBDonate (Beta 0) make sure the dropdown next to it is set to edit and click on GO.
3) In the field "Version" where it says "1.0.0" change that to 0.0.9
4) Then click on the first Save button.
5) Upload the new files and then import the new product xml.
6) That's it check out the new ACP options and front end stuff, enjoy.
Follow the below steps after upgrading!
1) Change the file extension of all the vBDonate Dashboard images from jpg to png, General Settings Image, PayPal Payment Settings Image, Donator List Settings Image, Change Usergroup Settings Image, Send PM Settings Image, Donation Bar Settings Image, Rotating Banner Settings Image, Sliding Banner Content Image, (settings found in the DragonByte Tech: vBDonate - General Settings) to see the new images made byKristerSwe
2) If you want delete the following images from the folder, dbtech/vbdonate/images/admin don bar.jpg, don list.jpg, general settings.jpg, pm.jpg, pp pmnt sett.jpg, rot banner.jpg, sliding banner content.jpg, user group.jpg they will no longer be used, and are just taking up space.
Bug Fixes And Issue Fixes:
Fixed: 2 defunct locations showing up under Rotating Banner Location settings.
Fixed: A issue with the border on the Donation List not showing in IE.
Fixed: A issue with some of the verified block text showing up twice, for new installs only. If you have the mod installed you need to edit it.
Fixed: Image quality of the paypal.png image and the verified.png image.
Fixed: A issue where only usergroup 6 could access the admin functions in the front end.
Fixed: A issue with some of the block elements on the Donate page and the Donation List page showing transparent.
Fixed: A issue with the Edit Entry link not working on the Donation list for Confirmed Donations.
Fixed: A display issue with one of the rows on the Donation List page not showing the proper background.
Changes To Existing Features:
Changed: The Donate Now link in the Donation Bar Now uses the same stylevar as the Donate navbar link.
Changed: The default Verified image on the Verified Block header to one with a transparent background.
Changed: The Donate link in the sub-navbar is now a dropdown menu, instead of just a link to the donate page.
Changed: The Usergroup To Change Or Add To in the DragonByte Tech: vBDonate - Change Usergroup Settings from a input field to a Radio Button tick box.
Changed: The text, "Go Back To The vBDonate DashBoard" on all the settings pages to a click-able image for easier identification.
Changed: The look of the admin setting pages.
Additions To Product From Feature Requests Or Just Something Else Added:
Added: A import function to import donations from AWCoding- Donation System into vBDonate. (PRO)
Added: A import function to import donations from VSa - PayPal Donate into vBDonate. (PRO)
Added: A stylevar to control the border for donation entries on the Donation List.
Added: A stylevar to control the border around the Donation Bar.
Added: Ability to easily change Verified image on the Verified Block header.
Added: A option to change the Donation Bar width to any percentage of the block you want, ie: 100% fills the whole block, 50% fills half the block and is centered.
Added: A option to be able to center the text on the Donation Bar.
Added: Ability to switch locations of the Donate Now text, or Donate Now image on the Donation Bar.
Added: Ability to switch between Donate Now text, or show a click-able image.
Added: Ability to easily change Donate Now image on the Donation Bar.
Added: Ability to have a image instead of the default Submit button on the Donate page.
Added: Ability to easily change the Submit image on the Donate page.
Added: Ability to change the width of the Donation Bar Block, ie: 100% fills the whole page, 50% fills half the page.
Added: Ability to center the Donation Bar Block if you have the block displaying smaller than 100%.
Added: Ability to set vBDonate in testing mode via PayPal's SandBox.
Added: Option to enter your PayPal SandBox E-Mail Address for testing purposes.
Added: A easy way for admins to see on the Donation List if it is a Real Donation or a Test Donation.
Added: Three additional paypal.png images and three additional verified.png images to choose form to show on the donate page.
Added: A vB option so you can have usergroups other than the group 6 act as vBDonate admin.
Added: Ability for users to view their donations on a separate donation list page.
