Cyrian
Hi,
I currently have Abe's Thanks mod installed, but want to import to this one.
I attempted to install the Lite version first. After about 24 hours, the script still hadn't gotten past the Post table. But the mod itself showed up in Products, so I hoped/figured it might have finished.
So I uploaded the Pro script and attempted to install. After 36 hours, it is still sitting on the Post table. Our forum has over 1 million posts, but it shouldn't take that long, should it?
I went ahead and stopped the script, and enabled the product. When I did, everything in the postbit disappears, save for the username (in plain text) and a user title of Guest.
As of now, I have both Abe's and this product disabled. I suppose I could try manually running the query as suggested in the VB.org post. But will it give me some other way of knowing the status of the Post table query?
If you manually run it, the installer will ignore those queries and move on with its business :)
Forgive me for the ignorant questions, I just want to be safe.
What query(s) should I run in phpMyAdmin?
Thanks
Not if you're running vBActivity and want to have this mod interact with that.
What version of the product does your AdminCP Product Manager show as you having installed?
Not using vBActivity. At least not yet. Only Thanks mod installed (kinda lol).
Product Manager shows 1.1.0 installed.
As I was typing this out, I realised it would be impossible to ensure this was working properly without actually seeing the database.
Can you PM me with the url to your phpMyAdmin installation and an user/pass, as well as FTP info and an admin account? I'll get it installed and everything imported properly :)
