Bug Uninstalling does not work
slapyo
I am having a problem with uninstalling vB Optimise Lite. I have tried to uninstall the plugin. It says it was successful and is no longer listed in products. The vboptimise folder still exists so I renamed it rather than deleting it and then I get errors when loading the site.
Warning: require_once([path]/vboptimise/core/class_vboptimise.php) [function.require-once]: failed to open stream: No such file or directory in [path]/includes/init.php(304) : eval()'d code on line 54
Fatal error: require_once() [function.require]: Failed opening required '/home/veterans/public_html/forums/vboptimise/core/class_vboptimise.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/veterans/public_html/forums/includes/init.php(304) : eval()'d code on line 54
This didn't uninstall I'm guessing. Trying to get it out of vB. I am having a problem with pages being cached even after logging in. I will see the login prompt. I login and it says welcome {username} and then it goes back to that page and it shows the login prompt still.
You have a plugin running on init_startup that was not a part of the vB Optimise product but still wants to load vB Optimise.
You'll need to find this plugin and deactivate it.
