Thanks for the post Hecter. I assume you are referring to the positioning of the tabs? Colours can be customized (depending on exactly what you want to achieve it would be either changing some StyleVars or changing some CSS in the templates). The Pro version does allow you to switch off the category tabs which would leave you with just the AJAX Tabs running.
Regarding the positioning of the tabs, I'll need to do some quick tests to see if we can move the template hook to a different location. If you are using anything that runs off that hook (I'm not sure what other mods you have running), it might present an issue.
I'll get back to you later this weekend on this. :)
PS, sorry for the delay in responding, I was travelling yesterday and have had a few internet connection issues... :D
Position is not important I am more looking for the look and feel of that tab and the functionality as well as being able to change the colours to suit my forums needs, is this all achievable with the pro version?
Yep. Much is doable with the Lite version. Test that first to see how much it covers your needs. My site runs tabs in different colours: The X Universe Forums
Having issues with this displaying forums see screenshot, this is on the default VB theme no matter what tab I click it shows no forums even though I have set all the permissions and forums, now and then it will show the forums but its once in every 10 clicks for example.
If you PM me some login details to the Admin Control Panel, I'll take a look for you this afternoon. :)
I think there is a bug in the Lite version. Try redownloading the latest 1.0.9 package and reuploading the files. If I'm right it should fix your issue. Let me know how you get on. (Download the Lite version from here at DBTech as I'll upload vb.org if this does fix your issue).
I downloaded it from here originally, but I have downloaded it again overwritten the files and the problem still persists.
Ok, made some more changes, can you try it again downloading the latest package and reuploading to your server? :)
Can you provide me with FTP access so I can try some things directly? From what I can see the updates aren't applying as I'm expecting them. FTP would let me check that properly. If you can, PM me the details. :)
I found one issue that wasn't helping, but it wasn't the source of your problem. I have got the Tabs working now by disabling the AJAX Tabs Quick Load option in the Settings. From what I can tell your forum is quick so it should make a minimal difference in terms of page load.
My best guess at the moment is that there is an incompatibility with one of your other mods. I'll try and identify which it is. :)
Had another look at things that you are running and it looks like several items might be contributing to the issue. However the setting I disabled should mean that some of the features some that your other mods introduce will still show. In short I'd say it's best that you leave the setting disabled and you will get maximum compatibility with all your other mods. :)
Same problem in my test forum.
Hope this is the only problem. Not that it comes in my production forum to bigger problems if I were to use the addon there.
We are concerned that it is in the live forum also to this problem.
Currently the addon is installed only in test forum.
Legacy DragonByte Forum Tabs
