Mantis
Unfortunately, I made a bit of a mistake buying this. It turns out the "lite" version did everything I wanted anyway. When I saw that you said that it supported ranks, I thought you meant something else rather than usergroups that's a bit primitive, so I bought it. I've migrated from MyBB, so I thought it would support the same features as the free MyBB plugin called My Achievements. You can see exactly what I mean if you view this page on the old closed forum I've migrated from. It worked so well and you could see ranks in the postbit. I guess there's no way I can go back with the upgrade.
You can still help me though. Is there any other solution that can do this for me, as it looks in the old forum I linked to? Alternatively, would you consider adding this ranks feature to the pro version of this plugin? It's a spectacular feature so I couldn't see why not. Thank you.
Upvote
