Valcav
Hello Fillip H.,
(for me it's not a that high priority, mainly because I haven't installed it yet on my live site. This is just something that happened on my test-site. And wanted to report it anyway.)
Yesterday I updated my (test-)forum from 4.1.7PL2 to 4.1.10.
& Today I enabled the plugin/hooks-system again, and I got only blank pages... (everywhere)
my quotes from http://www.dragonbyte-tech.com/f6/[4-1-10]-my-forum-updated-6032/
[13:53] Ozzy47: Enabled
[13:55] Valcav: well, tried on both anyway, still just blank...
[13:56] Ozzy47: I would post it in the support forum then, and explain everythig ya tried so far, and Fillip H. may be able to help
(PS: the "Website URL" I provided is my live site, if you want me to change it to the test-site let me know.)
I'm in the progress of updating my test-site
When turns out ok, then it'll be the Alpha-, Beta- & finally the Live-Site...
---------- Post added at 03:44 ---------- Previous post was at 03:10 ----------
I'm surely NOT saying it has to do something with DBT's mods, but just enabled the mods, and everything went blank... so had to disable the hooks via the config... That will be searching which of my products/mods is causing this...
Luckily this is just my test site![]()
done that,
only thing I didn't do is Activating mods one by one...
Done it via: Disable from the AdminCP: AdminCP > Settings > Options > Plugin/Hook System >
And then Enabled it again on there.
And then I got the Blank page:s
Which made me do: Disable from the config.php file: define("DISABLE_HOOKS", 1);
and then disabled it via the ACP > Settings > ... again so I could remove it from the config again.
But like I said,
not a real big emergency because it's just on my test forum...
& haven't installed any mods yet on the live site... so...
I just disabled all mods 1 by 1, then enabled the plugin/hooks system, and then I enabled vB Optimise, and that gave me the white pages...
I did a Maintenance -> Clear System Cache
And then enabled vB Optimise, but still white...
Can't do the flush cache in vB Optimise because it's all blank...
Any other ideas how to flush it? (or fix it?)
[13:53] Valcav: Ozzy47 , when the product is enabled? or disabled?Try typing this in your browser, of course change YOURSITE to whatever your site is.
http://www.YOURSITE.com/admincp/vboptimise.php?do=flush
