Please edit the issue above and, enter the URL of the website you're running / interested in running the product on, starting with http://.
Please note that an incorrect or invalid URL will mean we are unable to provide support.
Only DBTech staff see your URL.
You should probably do the same in your Client area to, http://www.dragonbyte-tech.com/clientarea/
1. The test on the localhost.
2. Next year will be a new site. Then it will be correct URL.
I buy a license and test products.
For example, to vb3 not very well looked slider 3.0.1, but 2.0.0 fine ..
vbshout 6.2.1 does not look very good, but the 6.0.8 fine ..
I'm looking for a good version for vb3.
The site will, but later...
Everything is there except the Attachment.
The database - dbtech_vbactivity_type - attachments - active = 0
then turns off
Legacy vBActivity & Awards
