So I upgraded from 1.02 lite to 1.10 lite to 1.10 pro (figured that was the right way to do it).
After doing so, nothing appears under the leaderboards tab and everyones points seem to be wiped, so I proceeded to clear the cache and then recalculate points under the vbactivity tools.
Leaderboards tab still shows nada, and many of my users daily activity percentages are at INSANE levels.
What do you guys suggest I do? This is the first day with the mod, so I do have the flexibility of removing and adding again if that is the best course of action. If the percentages are technically correct, so be it... just seems odd. But I would like the leaderboards working.
My forums are located at http://swiftor.com
Thanks for the help and the great mods!
