Asked before here - http://www.dragonbyte-tech.com/f105/jackpots-prices-11516/
How integrate in VBAA and where to put "user" for points table and "dbtech_vbactivity_points" for points field?
When i imstall this addon i have only one setting in vbarcade to put something
What i should put there? Have VBAA but not vb credits deluxe.
please some help
regards
bosss
HTML:
Alternate Points System
If you don't wish to use vBArcade with vBCredits II Deluxe, you can enter the column on the vBulletin user table that is used by the points system you are using instead, such as 'credits' without the quotes for the original vBCredits.
Leave this blank and make sure you have events for arcade access and high scoring under activity amounts configuration if you are using vBArcade with vBCredits II Deluxe. None of the currency related functionality will work if neither method is configured!
please some help
regards
bosss
